Re: Voltage loss at the starter - Farmall M gas
Posted by Heat Houser on January 05, 2013 at 16:32:39 from (69.66.35.73):
In Reply to: Voltage loss at the starter - Farmall M gas posted by Scott Flynn on January 05, 2013 at 12:02:14:
You are measuring at the posts, (not the clamps on the posts) and you are dropping from 12.2 V to 3.8 V.
There are two things that can cause this, the battery does not have sufficient remaing capacity to maintain 11 V while cranking or the load in the starter circuit is greater than what the battery can keep up with.
So, bad battery or a dead short.
Some times you can pull the caps and observe the water in the cells. If one is bubbling a bunch you have a bad cell.
Good luck.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
