Re: WD-9 has no spark
Posted by Bob M on January 05, 2013 at 18:55:06 from (67.240.174.32):
In Reply to: Re: WD-9 has no spark posted by red bearing on January 05, 2013 at 18:46:05:
First thing I'd do is disconnect the mag grounding wire that runs between the mag and the switch at the front of the manifold. If the mag now sparks there's a problem with the switch (contacts are not opening when the starting lever is in the "gas" position).
If still no spark, then look for the usual mag problems: dirty/improperly adjusted points, bad condenser, sticking impulse coupling, bad coil, etc.
