Re: what is the best/easiest way to get this 140 unstuck?
Posted by gene bender on January 06, 2013 at 06:16:17 from (67.55.226.151):
In Reply to: what is the best/easiest way to get this 140 unstuck? posted by PretendFarmer on January 06, 2013 at 05:51:39:
just remove the head. Then you can see the cycl walls and if they are rusty aint any snake oil going to help. If you do have a small mag type lite you can remove the plugs and see the walls easy that will tell you quick if removing the head and a teardown is the way to go. Headgaskets arent that much money and you can also see what condition the valves are.
