Re: what is the best/easiest way to get this 140 unstuck?
Posted by El Toro on January 06, 2013 at 06:33:23 from (108.3.143.30):
In Reply to: what is the best/easiest way to get this 140 unstuck? posted by PretendFarmer on January 06, 2013 at 05:51:39:
third party image
Do as Gene suggested and pull the head. Those sleeves are wet sleeves and you can drive the pistons and rods out with the sleeves. Once you
get the sleeve and piston out use a torch to remove the piston. New sleeve kits are available here on this forum. I did this on a Farmall A in 1975 and I pulled the engine. Hal
