Posted by SDE on January 06, 2013 at 07:43:33 from (174.124.47.156):
In Reply to: Frozen m posted by Notjustair on January 05, 2013 at 10:49:04:
I was working on an F-20 one day. The entire tractor was wet from "sweating". If the outside is wet, the inside will be wet also. This is where some of the moisture came from. If you work the tractor hard and long, you can burn the water out of the Transmission and rearend housings. If you don't, you will need to drain them ever few years. I drained some water out of a 400 before we towed it home. The remaining water never seperated back out of the fluid. I had my 400 freeze up one winter and I applied the heat and made a tent. Then drained out as much water as I could, until I started to get fluid coming out. It has been ok since then. SDE
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
