Re: what is the best/easiest way to get this 140 unstuck?
Posted by MisterT on January 06, 2013 at 10:44:59 from (216.248.71.226):
In Reply to: what is the best/easiest way to get this 140 unstuck? posted by PretendFarmer on January 06, 2013 at 10:33:22:
What little you can see from peaking through a spark plug hole will tell you nothing. If the piston is at the top of the stoke, you will see the top of the piston, but that is just about all you will see.
Also, I have encountered a few VERY stuck engines myself, and I have tried every method mentioned right here in this thread and NONE of them worked. Even after letting one one engine set and soak for better than one year, I still ended up taking the pistons out in pieces.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
