Re: Brakes on SMTA
Posted by Janicholson on January 06, 2013 at 11:03:19 from (74.60.94.18):
In Reply to: Brakes on SMTA posted by Ellis Kinney on January 06, 2013 at 08:53:24:
Good addition. Using a dremel and small stones. Or a flat file if you are good with a file, can remove some burrs and wear edges, but if more than .008 or so the wear might need to be modified at the new disk by polishing (or turning on a lathe) the female splines to allow full movement of the new disks. Thanks. Jim
