Re: Weak starter??
Posted by gene bender on January 06, 2013 at 17:50:21 from (67.55.226.151):
In Reply to: Weak starter?? posted by equeen on January 06, 2013 at 15:00:48:
How is the switch on the starter then new ground cable. Then a new cable going to the starter. Then new brushes in the starter and clean the commutator and a new bushing and bearing. Remember the starter is a left hand rotation as the bendix is toward the driver and not forward as other tractors. Just because the batt ends are clean doesent mean they are good.
