Re: What I found today
Posted by The tractor vet on January 06, 2013 at 20:32:22 from (75.19.126.114):
In Reply to: What I found today posted by Zachary Hoyt on January 06, 2013 at 19:48:20:
Well and old trick i have used on setting up and ring and pinion is heavy black grease . NOW KEEP IN MIND HERE that the BOOK gives set up for NEW not used and always use a set , not this part from one and the other from another and try and get the shims from the donor tractor . also do not try for FACTORY SET ON BACKLASH . IF you have a good centered drive and a decent coast and you can not throw a cat thru on the backlash your good to go . And one tiny little tidbit , when your putting things back together take a heavy rubber band and wrap it tight around the input bearing as this keeps the rollers tight and less chance of knocking them out when you put the T/A housing on and also use guide studs . Don't worry about removal of the rubber band as it will dissolve over time .
