Re: M head stud removal
Posted by Dave_Id on January 07, 2013 at 06:00:33 from (107.207.72.252):
In Reply to: M head stud removal posted by ss409 on January 07, 2013 at 05:39:02:
Lock two nuts together on the stud,if your favorite thread loosener doesn't work, then try heat. If that does't work, then you may have to grind it flush, redrill and tap it.
