Re: What I found today
Posted by Janicholson on January 07, 2013 at 10:02:54 from (74.60.94.18):
In Reply to: Re: What I found today posted by Zachary Hoyt on January 07, 2013 at 04:48:47:
The Prussian Blue is called that as far as I know everywhere. The pattern should be centered in the height and length of the teeth (drive and driven).
The straight bevel gear will have a pattern that is longer along the tooth than the spiral bevel shown.
Put drag on the ring gear by applying the brakes while turning the pinion. There is no adjustment for perpendicularity as the case is the case. Also there is no up and down alignment for the same reason. Adjustments are pinion rearward (in), or toward the trans (out), and backlash ring gear into mesh or out of mesh farther. Good luck, Jim
