Re: 766 gas to a Diesel change over
Posted by mkirsch on January 07, 2013 at 12:42:01 from (64.80.110.74):
In Reply to: 766 gas to a Diesel change over posted by Icuby on January 07, 2013 at 10:49:40:
Just to do the basic mount-up in the frame, you need:
tractor flywheel
clutch
pressure plate
front engine cover
rear engine plate
oil filter base
manifolds
Then you need to figure out fuel lines, radiator, throttle linkage, oil pressure, alternator, engine temperature, tachometer, exhaust hole in hood. One dilemma is you have a choice of either having a fuel gauge or a return line for the injector pump.
