Re: Weak starter??
Posted by old on January 07, 2013 at 17:50:56 from (209.86.226.30):
In Reply to: Re: Weak starter?? posted by equeen on January 07, 2013 at 17:29:12:
Check at your local welding equipment place I bet you can buy welding cable cheaper then that by the foot and it makes great battery cables
