Posted by Owen Aaland on January 07, 2013 at 21:19:03 from (216.47.35.211):
In Reply to: Weak starter?? posted by equeen on January 06, 2013 at 15:00:48:
A load test of the battery and a few simple tests with a volt meter would soon show where the problem is.
If the battery loads test passes then look for voltage drop all along the circuit from one battery post all the way back to the other. Look for no more than .1 volt drop across any connection and no more than .2 volt drop across any switch. If you have more than about 1.5 volt drop across the starter when it is engaged you either have a starter problem or the engine is not turning over freely.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
