The high top piston raises the compression ratio, so as a general rule you can make more horsepower, that is why they are popular. If you are using the tractor in a high altitude area the higher compression will make up some of the power loss from the thin air. It will help a bunch if you can get the connecting rod loose, then when you are tapping from the top you won't be pounding the rod bearing and the piston and rod will have somewhere to go. If it has any real rust you are going to want to clean the piston and rings anyway.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
