Re: 706 D 282 hard to start
Posted by mkirsch on January 08, 2013 at 05:22:35 from (64.80.110.75):
In Reply to: 706 D 282 hard to start posted by Scott Hite on January 07, 2013 at 19:40:56:
If it fired right off when you pulled it, then cranking speed is your #1 issue.
Try replacing those ratty old undersize battery cables with new 0ga, running separate + lines from each 12V battery direct to the solenoid, and separate - lines from each 12V battery direct to one of the bolts on the starter mount.
