Re: my stuck 140, update
Posted by old on January 08, 2013 at 09:22:54 from (209.86.226.18):
In Reply to: Re: my stuck 140, update posted by PretendFarmer on January 08, 2013 at 08:57:38:
Just be careful not bugger up the crank shaft when you pop that sleeve out. When I built my BA I pulled the sleeve out of the B block which was locked up real bad and dropped in the sleeve out of the A block I had, the A block was broken in more then one place. so I took 2 engines and built one good engine and pretty much only used new parts when I could not get by with used one. I even used a used head gasket and that was 2 years ago and ran it all summer this past summer
