Re: super c drive major issue
Posted by Hendrik on January 08, 2013 at 14:09:19 from (194.53.253.51):
In Reply to: super c drive major issue posted by adam h popper on January 08, 2013 at 12:16:00:
All suggestions below are good.
You could also check whether the PTO still works. The PTO is driven by the primary (input) shaft of the transmission, which, in turn, is driven by the long shaft that runs from the clutch to the transmission (through the torque tube).
There are one or more holes in the underside of the torque tube. Peek up and see if the shaft is turning.
HTH
