Charles Weller Mower answer
Posted by Janicholson on January 08, 2013 at 15:40:24 from (74.60.94.18):
The wooden board for the tip is called a Swath board or parting board and lays the hay in what might be called a ""part"" like on your hair.
The mower has a pair of plates that go under the draw bar of each (tractor and mower) they are about 3 inches wide each and 1/2 inch thick. (mild steel is fine) they are made by putting the mower up to the drawbar on jacks or blocks (a bit cumbersome) so that it is parallel and at the same level. Make a template from cardboard for the holes, two holes in each plate for the mower, and one hole each for the drawbar. This provides all the needed mounting. Have the plates plasma cut from 1/2, or 5/8 plate and bolt it to the drawbar. Be sure to have enough PTO drive shaft compression length so the mower can follow terrain. (probably at least 6 inches of compression and extension) Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
