Re: Tie down attach points for show tractors
Posted by rhtx55 on January 08, 2013 at 16:50:21 from (68.185.207.25):
In Reply to: Tie down attach points for show tractors posted by Baelee05 on January 08, 2013 at 06:59:14:
I use a plate that bolts to the front bolster, use a clevis and chain there to both corners on the front of the trailer, I use clevis(s) on the rear drawbar holes & use chains there in the rear.
Never had one move, the trick is to bind it down tight, then recheck & re-tighten after 20 mins of driving, this is usually where it will "settle" & remain tight afterwards.
I beleive you will get a differing response from each individual. The above method worked going from Missouri to Indiana with a 45 H.
