Re: Tie down attach points for show tractors
Posted by Paul from MI on January 08, 2013 at 18:05:57 from (204.106.250.243):
In Reply to: Tie down attach points for show tractors posted by Baelee05 on January 08, 2013 at 06:59:14:
I make a strap of 3/8 x 2 in a "U" shape that mounts to the frame rails just behind the front tires. One leg of the "U" is bolted to each frame rail, or side of the bell housing, and then a chain/binder can be hooked to each side of the trailer. At the rear I bolt a 3/8 thick plate with a hole in it big enough to allow a 2 grab hooks to be inserted. That allows 2 chains/binders to be used on the rear. I realize that by law the tractor must weigh over 10,000# to require 4 chains, and none of mine do, but having a very secure tiedown system may prevent a stop from the DOT, which you DO NOT want. By using added tie down points the finish on the restored tractor is not damaged.
