Re: Tie down attach points for show tractors
Posted by Jim Becker on January 08, 2013 at 18:20:38 from (173.74.120.222):
In Reply to: Tie down attach points for show tractors posted by Baelee05 on January 08, 2013 at 06:59:14:
(reply to post at 20:47:37 01/08/13)
That page has some formatting problems, makes it a bit hard to see what applies to what. I believe the entire heavy equipment section is as below. The formatting runs on into secion 132, Crushed Vehicles, which does prohibit synthetic webbing.
Section 108 of the regulation also states the well known adage about weakest links. The eye bolts I see at most shows are no doubt the weakest links when they are used. They have very low load limits. Look into the details before using them!
