Re: Which is the correct radiator cap for a '41 H ?
Posted by Zachary Hoyt on January 08, 2013 at 19:15:01 from (184.10.236.70):
In Reply to: Which is the correct radiator cap for a '41 H ? posted by Yooper Farmall on January 08, 2013 at 19:09:28:
The upper style is for the non-pressurized radiator, the lower is for pressurized. Look at the radiator filler neck and you will see which one you need. The pressurized one has a ledge inside it like a car radiator while the non- one looks more like the gas tank filler neck on the tractor.
Zach
