Re: Zerks on the end of rear axles
Posted by Janicholson on January 08, 2013 at 19:38:34 from (74.60.94.18):
In Reply to: Zerks on the end of rear axles posted by Bkpigs on January 08, 2013 at 19:28:59:
The outer bearings are lubed by grease. The grease is less likely to run out on side hills. the grease is also better at keeping dust and mud out of the housing. Every week of real use give it 2 pumps. Jim
