Re: Int/Farmall 826
Posted by The tractor vet on January 09, 2013 at 08:10:32 from (75.19.126.114):
In Reply to: Int/Farmall 826 posted by matt illinois on January 09, 2013 at 06:44:46:
Good solid tractor . Weak point is the T/A . IF the T/A is good and you want to keep it that way ya just follow the rules . (1) never use the T/A to slow down (2) keep the clutch , trans brake and dump valve in proper adjustment Change hyd. filter and Hy Trans as spec. They have a good engine that likes to be worked , not putts around as they will wet stack . I always wanted one but each time i got one someone just had to have it as they sold well so i just kept on farming with what did not sell fast . Don't know what the price is but i know what i use to have to give for them years back and what they sold for . So i am guessing here that IF you can get it for 6500-8500 and it is a descent looking tractor with good rubber and good sheet metal and everything works ya got a bargain.
