Re: '59 140 hyd help needed
Posted by Curt Cooke on January 09, 2013 at 13:56:12 from (64.186.50.66):
In Reply to: Re: '59 140 hyd help needed posted by d padgett on January 08, 2013 at 10:28:10:
My point was going to be that if that tractor came from the factory to operate a sickle mower, the actuators in the hydraulic unit will be shorter than normal. This was done so that one could not "drop" the mower too fast. These actuators cause the hydraulic arms to come back toward you very slowly, they move away from you at a normal speed. But it sounds like you've had the tractor for some time and this is a recent phenomena.
Are you using proper Hy-Tran fluid?
