Re: This a Farmall seat pan or an aftermarket seat ?
Posted by Lmack on January 09, 2013 at 14:12:28 from (24.131.58.167):
In Reply to: This a Farmall seat pan or an aftermarket seat ? posted by Yooper Farmall on January 08, 2013 at 18:53:41:
The Farmall seat has a clip spot welded to the bottom with provision for four mounting bolts. Check the CIH web site for a picture. I could not get a good look at the bottom of your seat pan so I could not tell if it resembled the Farmall seat. I have a pan with two mounting bolts through the seat pan and it was an aftermarket seat. My 200 has a standard Farmall seat with four bolts. I guess I could get some pictures of the four bolt Farmall set up if you needed it. Send me an email if you need pictures.
