Re: Slight Miss in 300
Posted by rhtx55 on January 09, 2013 at 16:28:33 from (68.185.207.25):
In Reply to: Slight Miss in 300 posted by Va Gasman on January 09, 2013 at 05:21:23:
Drain the tank or run all the old gas out, it probably has a bit of condensation built up. Replace with a full tank of fresh gas.
If the new gas doesn't do it, open the main jet on the carb bowl out a turn & a half ( counter clockwise). If it blows a bit of black smoke under load you are close on the main setting. You want the main jet out as far as possible with little to no black smoke under load at full rpm.
