Re: wiring question
Posted by Janicholson on January 09, 2013 at 17:54:58 from (74.60.94.18):
In Reply to: Re: wiring question posted by marc walker on January 09, 2013 at 17:34:06:
The diode goes in the wire from #1 to the ignition, with the band on the diode toward the alternator #1 spade terminal. The #2 terminal should be connected to the Big output terminal going to the amp meter. (short lead) it needs to be able to handle about 3 amps. (an old alternator can be scavenged to take apart the diode bridge removing one of the 6 diodes. (these are often not marked for polarity, so test it to assure it cannot pass electricity from the alt to the ign. but will from ign. to alt. Jim
