Re: td-6 wiring
Posted by Janicholson on January 09, 2013 at 17:59:06 from (74.60.94.18):
In Reply to: Re: td-6 wiring posted by b-rad on January 09, 2013 at 17:32:46:
As far as original with a generator, they were all positive ground. Pos to Pos etc. If changed to negative ground that is OK as well as long as it has a generator, and is polarized before starting it. The battery terminals should be big and small, as a result the battery should be correctly installed that way. If jumping always Pos to Pos Neg to Neg. No exceptions. Jim
