Re: Super C exhaust temp.
Posted by Janicholson on January 09, 2013 at 18:42:50 from (74.60.94.18):
In Reply to: Super C exhaust temp. posted by Rick Remmert on January 09, 2013 at 15:58:28:
The gauge will work. The temp will likely be in the 800 to 950 range working pretty hard. It won't tell you much until an exhaust valve burns really bad. then it will get to 1200 or so.
The engine carb is not adjustable for high speed load mixture. It is a fixed jet carb. If for decoration do it if for diagnostics, a laser hand held unit is far more like a tool, and can be used on 1000 things. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
