Re: IH 674 D239 Engine replacement
Posted by rustred on January 10, 2013 at 08:06:07 from (209.115.232.65):
In Reply to: IH 674 D239 Engine replacement posted by ClarkR on January 10, 2013 at 07:14:18:
well if you say it has ben run with diesel in the oil then thats a very good reson for the blowby. the diesel glazes the cyl. walls and the tractor will use a lot of oil. the most likely cause would be the injection pump shaft seal leaking diesel into oil pan.
pull the head off first and check things out. may only need a set of rings and deglaze cyl's. best is to check this engine out first before getting involved with another one. you may get away a lot cheaper.
