Re: heisler overdrive for m farmall
Posted by D Slater on January 10, 2013 at 16:44:32 from (184.15.8.141):
In Reply to: heisler overdrive for m farmall posted by zanslastclu on January 10, 2013 at 11:00:43:
third party image
third party image
third party image
Not sure but think you may be looking at a hiesler 9 speed shift shaft thats missing the shift lever. Heisler also made a hydraulic pump drive disconnect.
If the pictures work, first is a hiesler. Next is a model of M&W that also had a left side shift. Last is a M&W right side lever shift lever without the M&W shift rod to the lever. Look past the hydraulic valve to the lever in front of the brake pedals. M&W also used a push pull cable shift like used for pto operation on some trucks.
