I really like that design. Only thing I would change is to add either one (or maybe two) 1/8" x 1 flat straps welded in the middle with the welds ground flush of course. Doing this would support the middle of the plastic battery case which is currently only supported around the perimeter. Adding this would prevent the plastic battery case from sagging in the middle over time.
Regardless, That box looks very nice and looks so much better than the hack jobs that many people hang of the side of the frame rail. I simply can not stand those of the side of the frame rail hack jobs you see so many people cobble together on ole h's and m's. Also, I totally hate the bungy cord interweaving job people sometimes do as that looks like crapola as well.
Your solution is both elegant and very functional and should be quite durable being made out of 1/8" stock instead of sheetmetal. I expect your design could be copied quite a bit. It is a model template that could be easily made with the most basic of welding tools. Even some of those junky dirt cheap $59 welders could handle this project easily. I admire designs that are practical and this is one of them.
This post was edited by rankrank1 at 04:35:04 01/11/13 3 times.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
