Re: 263 in a 606
Posted by mkirsch on January 11, 2013 at 06:34:47 from (64.80.110.74):
In Reply to: 263 in a 606 posted by steve in wi on January 11, 2013 at 05:02:26:
To the best of my knowledge, the base block is the same outside dimensions for the 221 and 263.
You will basically need to strip everything off the 221 block and put it on the 263 block. The 606 doesn't have a frame like the 706 so all the mounting is likely to be different.
