Re: 3588 AC question
Posted by Owen Aaland on January 11, 2013 at 16:26:28 from (216.47.32.165):
In Reply to: 3588 AC question posted by Youngin on January 11, 2013 at 12:02:04:
Youngin said: (quoted from post at 16:02:04 01/11/13) We have 3588 with ac troubles. When the low pressure gauge gets to about 70 and high pressure to 50 it just runs until the high gets to 100 then the compressor shuts off. Then it wont kick on for a while. I have no juice at the yellow wire at the relay cut out. If i jump juice to that wire the compressor runs. Should their be juice their?
Thanks
What does the low side pressure read once the compressor starts?
There is a low pressure switch in the cab on the return hose from the evaporator and a high pressure switch near the condenser in front of the radiator. The low pressure switch should close at 6 +/- 2 psi. The high side switch should close at 375 +/- 10 psi. Both switches must remain open for there to be "juice" at the compressor clutch.
Pete, Thanks or catching the errors .
This post was edited by Owen Aaland at 16:59:15 01/12/13.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
