Re: Farmall 560 Restoration FINISHED!!! PICTURES!!!
Posted by Janicholson on January 11, 2013 at 19:36:00 from (74.60.94.18):
In Reply to: Re: Farmall 560 Restoration FINISHED!!! PICTURES!!! posted by farmallboy15 on January 11, 2013 at 17:43:35:
Fine work. You will never starve if you have the willingness to work as hard as you have on that tractor. Good luck at school. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
