Yes it will fit and work. May be slightly under fueled. Fuel adjustment is stop on lower shutoff lever when in run position. Just be sure to determine you know where timing marks are on both before removing them. Lot easier than after you have them off. They are a little hard to see on those pumps. Should come up at about 12 to 14 degrees btdc, line comes up to just flush with bottom of pointer in pump.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
