Posted by Jcrank01 on January 12, 2013 at 10:03:32 from (166.205.55.42):
I recently bought a set of 496 disk. When you try to fold them back up only the left side will raise. It will attempt to lift the right side and if I physically pull up on the wing it will go on and raise. When you lower them it will raise right back up as long as you don't let it go all the way down. I speculate that one or both of the cylinders has an internal leak and is bypassing oil.
Also, what holds the pins in the pivot point where the wing wheels raise up and down. I can't seem to find and bolts that hold them in. Almost as if they are pressed in but I can't imagine that they're pressed in. I want to remove those pins so I build the pivot point back up and get the play out of it. Any input is appreciated
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
