Well the engine is sleeved. (dry sleeves) if you remove the existing sleeves thinner sleeves can be installed. It will not quite get to the SH dimension, but with higher compression domed pistons it will be more powerful than a stock SH. All other efforts will require boring out the cylinder block to larger diameters for bigger sleeves, or running with no sleeves. Putting a 350 engine block in it and using thinnest sleeves in that with high compression pistons (and its cam carb intake and distributor is about as powerful as you can get without compromising farm use or getting carried away with making a puller only. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
