Posted by pete 23 on January 12, 2013 at 11:56:26 from (74.32.229.189):
In Reply to: 450 questions posted by mike Fitz on January 12, 2013 at 11:40:47:
Hydraulic valves are same, excluding the inner most valve on tractor with power steering and of course the flow divider valve block. Assuming factory power steering.
Far as governor, all external linkages must be in good enough condition so internal high and low stop can be reached with throttle lever. Then you would have to go for internal thrust bearing and link between gov and carb condition. Worn out weights or weak spring will cause poor response to load but not affect making it idle down slow. Loose worn throttle shaft and bushing in carb also.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
