Re: Char Lynn question
Posted by Janicholson on January 12, 2013 at 13:05:27 from (74.60.94.18):
In Reply to: Char Lynn question posted by Notjustair on January 12, 2013 at 12:47:24:
Teflon based Orings in several hardness levels are readily available. Google PTFE Orings and shop.
PTFE stands for Polytetrafluoroethylene (Teflon)
An Oring of teflon will be good to go. Jim
