Re: Hard starting M
Posted by Janicholson on January 12, 2013 at 15:26:02 from (74.60.94.18):
In Reply to: Hard starting M posted by Animal on January 12, 2013 at 14:44:13:
If the choke plate is centered in the intake bore, it should be as ffective as your hand. A caeful look inside might show the issue. The screws have been known to unscrew. There might be a spring loaded valve in the plate as well which needs to be held against its hole. Also make sure the choke rod or cable is making full movement. Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
