Re: Re: New carb on 1945 A
Posted by Dave G. on November 02, 2000 at 18:04:41 from (63.91.152.8):
In Reply to: Re: New carb on 1945 A posted by T_Bone on November 02, 2000 at 10:49:45:
It's running a lot better now. Checked out float level and it was off. Reinstalled it. Did then have a problem with hunting at full throttle, but turned in the bottom governor screw about 1 full turn (1/2 turn at a time) and that seems to be OK now. Float was not off much, but enough to give a fuel level too low in carb. Should have checked it out before installing even though it was new. Those things probably get bounced around a lot before ending up on the tractor. Also starts really well now. Thanks again.
- Dave G.
Post A Followup
: Re: Re: Re: New carb on 1945 A
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
