Posted by jimb2 on January 13, 2013 at 09:26:25 from (99.241.76.141):
In Reply to: injector pumps posted by 292 Ralph on January 13, 2013 at 07:44:44:
Hi Ralph, I believe early B275's had an inline injection pump like B250 and later ones had CAV rotary pumps the same as B414D, 434, 444 and 384. Also I don't know if the fuel setting has to be changed for a CAV pump between B275 and B414 or if the fuel delivery is controlled by the injector tips. The B275 is a BD144, 144 Cu inch engine and B414D is a BD154 154 Cu inch engine, so if fuel is controlled by pump then without re-calibration the B275 will smoke a lot. Maybe MJ in UK or some other CAV pump expert will offer an opinion.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
