Re: Zenith Carb for Super M?
Posted by MisterT on January 13, 2013 at 11:12:32 from (216.248.71.226):
In Reply to: Zenith Carb for Super M? posted by smith1000 on January 13, 2013 at 10:56:25:
smith1000 said: (quoted from post at 19:56:25 01/13/13) Is there a Zenith, or other aftermarket carburetor available for a Super M? I continually have problems getting the M started in the cold. I run a heater on the oil pan, but it doesn"t seem to help. Sometimes, it will fire and then die and then it will never start after that until it sits for a long time. If I somehow catch it on the first firing, I can sometimes keep it running, but it seems like it is a one chance deal. Gasoline will run a stream out of the carb. It has been rebuilt, but has always done this in the cold.
That's just how it is. In cold weather, the trick is to get the engine spinning over and THEN pull the choke, but only briefly. Basically, pull it out and then shove it right back in. Once the engine fires, then work the choke as needed to keep it running.
The only option is to install an engine coolant heater.
For what it's worth, the carburetor you have was built by Zenith, For IHC.
This post was edited by MisterT at 11:13:55 01/13/13.
