Well in response to both, the points are new but I will rub the contacts, timing has not been changed or touched, I am very careful to be sure everything is aligned just as it was when I first pulled the mag, But even if timing was out should I not get a spark indication directly from the secondary side of coil. I am confused as continuity is good with no grounding to anything, except points show continuity to ground when my coil is hooked up, but I read this is normal since resistance is so low on the primary side. If points and condenser are new and have been replaced, what could possible change by just sitting for 4 years.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
