Posted by Patrick HMD on January 13, 2013 at 14:57:30 from (75.9.218.111):
I finally got the courage and pulled out the output shaft on my belt pulley. (First time) Easier than I anticipated. A little tapping with wood block and hammer, and out it came. The same with the shaft. All the parts on the shaft came off rather easy using a wood block and hammer. Didn't need a press. Now I have 2 questions.
1. The oil seal. (#49177D) Which way? I have conflicting info on that. My I&T shop manual says the lip should face the bearing, and they're calling it a leather seal. Now, my IH service manual says the lip of leather seal is toward the pulley. Which is the proper way? or does it matter that much. Mine has the lip facing toward the pulley.
2. The felt washer. (#49133D) The oil seals seem to be in abundance, but I'm coming up short on the felt washers. Who has these? I'm thinking I can reuse the old felt washer. Right now it's totally, totally saturated (soaked) with oil, but still has it's good original shape. I see that by squeezing it between several layers of paper towels, the oil can be blotted off. Seems like if I keep doing that, the washer will eventually become drier and more useable. Would that work? But really, I would rather have a new one. The instructions do say to soak the washer in oil before hand, but I feel that mine is a bit too saturated to work properly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
