Re: crank pulley
Posted by old on January 13, 2013 at 20:54:45 from (209.86.226.32):
In Reply to: Re: crank pulley posted by tuckaway on January 13, 2013 at 19:37:22:
Do not feel to bad. I have 2 or 3 of those pulleys out in the shop with pieces broke out of them from trying to pull them off. Years ago I made a pulling plate out of 1/2 inch plate that has 2 pieces to it both cut with a U shape and those pieces bolt together so I can then use a gear puller on the plates
