Re: H4 magneto Checked and gone through, no fire
Posted by El Toro on January 14, 2013 at 04:58:24 from (108.3.143.30):
In Reply to: Re: H4 magneto Checked and gone through, no fire posted by Daniel Dillon on January 13, 2013 at 20:31:36:
If you have battery start you can convert your mag to a distributor using an auto type coil.
You would need an ignition switch and wire to run voltage to the switch and to the coil then to the points. Disconnect the coil wire at the points from the mag's coil. Hal
